Discussion => General Board => Topic started by: Keith Bollwahn on December 03, 2001, 12:21:36 pm
Title: Generating DDL Schema
Post by: Keith Bollwahn on December 03, 2001, 12:21:36 pm
 ??? When generating DDL from EA, is there a way to reset the target path to null so the application will prompt for a target the next time I run the generation?
Title: Re: Generating DDL Schema
Post by: sparks on December 04, 2001, 03:43:40 am
I am assuming you have been generating DDL from the package level, so you do a group of tables at one time.  ie the bulk generate.
The alternative to this is to generate each table individually.  To do this right click on a table and select "Generate DDL..." you will be shown a screen where you can change the output filename and if you want, generate the DDL SQL for the selected table.
Hope this helps.
Paul Mathers
