Discussion => Suggestions and Requests => Topic started by: Arquesoft on June 29, 2017, 01:02:18 am
Title: Be able to upload model images connected via Cloud
Post by: Arquesoft on June 29, 2017, 01:02:18 am
It is frustrating when you use the advantages of implementing Cloud Server in a company that has been using connections via ODBC to the EA Repository, but it is not possible to upload model images in order to be used as alternate images for elements.
Title: Re: Be able to upload model images connected via Cloud
Post by: Graham_Moir on July 03, 2017, 11:21:19 pm
Yes, but rumour has it that there is a fix coming in 13.5
Post by: Arquesoft on July 13, 2017, 11:50:14 pm
Not possible in 13.5 Build 1351.
Post by: Arquesoft on July 24, 2017, 11:39:30 pm
When trying to upload the image via the Model Images window, it throws the following message in the System Output Window:
Cloud Services: Query in batch execute failed with message: FAIL: Microsoft OLE DB Provider for SQL Server [-2147217900] Cannot insert explicit value for identity column in table 't_image' when IDENTITY_INSERT is set to OFF.
Post by: T Kouno on July 25, 2017, 09:32:16 am
Hello MMoya,
The help file says that you need ALTER permission, like below:
You have ALTER permission on the t_image table in Enterprise Architect, to be able to import model images
( http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/model_repository/connecttosqlserver.html )
Post by: Arquesoft on December 13, 2017, 05:52:23 am
As tested in a real environment (and confirmed via Sparx support), ALTER permission is not enough to make it works properly. Not found yet a solution.
