Discussion => Bugs and Issues => Topic started by: slaza on December 06, 2017, 10:52:12 pm
Title: Setting connectors only show in the current diagram by default
Post by: slaza on December 06, 2017, 10:52:12 pm
Dear All,
When I add a new connection to a diagram, it automatically shows up in all other diagrams. I need to switch off visibility manually for each and every new connector.
Is there any way to set the default visibility of a connector to show only on the current diagram, and I can switch visibility on if I wanted to anywhere else?
(I am sure that I am not the first person to ask this, but I just can't find the answer...)
Title: Re: Setting connectors only show in the current diagram by default
Post by: Geert Bellekens on December 06, 2017, 11:02:09 pm
The answer is: you can't, and you shouldn't.
If you find yourself in the situation that you need that,  then you are doing something wrong.
Hiding relations should be an exception, for example when creating an overview diagram that you don't want to clutter with too much relations.
