Discussion => Uml Process => Topic started by: adriang on January 13, 2004, 05:25:37 pm
Title: Non Functional Requirement / Use Case
Post by: adriang on January 13, 2004, 05:25:37 pm
I know that it is appropriate to use a "realization" line to link a Requirment element to a Use Case element, but what kind of link should be used when dealing with a Non Functional Requirement and a Use Case?
Title: Re: Non Functional Requirement / Use Case
Post by: CJ on January 14, 2004, 09:44:02 am
G'day,
I link all requirements, irregardless of the type, to elements via realization links.
What kind of requirement are you looking at?
Post by: adriang on January 14, 2004, 10:46:15 am
A non functional requirement which would be used be observed by many use cases.
Post by: CJ on January 14, 2004, 11:55:05 am
G'day again,
I'd stick with the recommendation on using the realization link.
I guess the only question for your situation is whether it is better to link your use cases to the non-functional requirement, or link other types of elements to the non-functional requirement.
Post by: Bruno.Cossi on January 14, 2004, 12:06:07 pm
Does Non Functional requirement refer to stuff like "All the reports must be available in English, French and German"?
For situations like these, we still use realization relationship.
Bruno
Post by: adriang on January 14, 2004, 05:27:17 pm
The situation I'm dealing with might fit in that category.  It would be a performance requirement which would apply accross many use cases.
For example:
UC1 - Retrieve Student Records
UC2 - Retrieve Class Schedules
Non functional requirment: All data retrieval must take no longer than 5 seconds.
Both use cases would need to comply with this requirement.
Post by: Bruno.Cossi on January 14, 2004, 06:12:46 pm
We have had much the same situation and realize relationship worked just fine.
Bruno
Post by: adriang on January 15, 2004, 08:17:31 am
We'll probably use realize links.  Thx.
