Enterprise Architect => General Board => Topic started by: skiwi on August 03, 2018, 11:29:27 am
Title: Generate documents based on element tag
Post by: skiwi on August 03, 2018, 11:29:27 am
Has any generated document by using tags?
I've got the idea of retricting the elements in a document by generating a document using tagged values.
For example the model document only generated from elements where to tags are specified, or one of a specific set of tags is applied to the element?
tia
Simon
Title: Re: Generate documents based on element tag
Post by: Geert Bellekens on August 03, 2018, 04:07:02 pm
You can add a filter in the template properties to restrict the tagged values.
Alternatively you can also use a search on a model document to select the elements you would like to report.
