Enterprise Architect => General Board => Topic started by: sbleden on September 10, 2018, 11:23:49 pm
Title: Create Replica of a Design Master via CommandLine
Post by: sbleden on September 10, 2018, 11:23:49 pm
Hey Guys,
i just wondering if its possible to create a replica of an existing Design Master via the Command Line?
Greetings
Bastian
Title: Re: Create Replica of a Design Master via CommandLine
Post by: Geert Bellekens on September 11, 2018, 12:58:08 am
Bastian,
Stop right now and find an alternative for the replica mechanism.
This MS Access mechanism is shaky at best and it will come back to bite you sooner or later.
Post by: qwerty on September 11, 2018, 07:25:07 am
I'd say: more sooner than later.
However, if you're sticky to that Mickeysoft stuff just go and google for "MS Access replica" since EAP is just that.
Post by: bpirk on September 13, 2018, 04:54:38 pm
Hey,
thx for the answers.
Is there another way, the work offline on the same eap file and merge it later?
Greetings
sbleden
Post by: Geert Bellekens on September 13, 2018, 05:28:00 pm
Hey,
Greetings
sbleden
Hi, you can't really merge models, but you can use version control to work together in offline mode.
The difference is that you check-out a package for exclusive use. Until the package is checked in again, other people won't be able to edit that package.
You can connect a bunch of different version control systems, but the most common ones are SVN and TFS.
