Enterprise Architect => Bugs and Issues => Topic started by: michielper on August 08, 2019, 12:27:16 am
Title: V13 Archimate2 Exchange does not include FLOW relations
Post by: michielper on August 08, 2019, 12:27:16 am
When I export my Archimate 2 model using Sparx EA version 13, FLOW relations are NOT exported and do not appear in the generated XML file! All other relations are present. This of course is a serious bug and hampering my work.
Has this been resolved in a newer version?
Title: Re: V13 Archimate2 Exchange does not include FLOW relations
Post by: Glassboy on August 08, 2019, 07:25:15 am
I've just tested it in 13.0.1310 and it works.  Have you checked you do have an ArchiMate 2 flow stereotype on the relationship you're trying to export?
Post by: michielper on August 08, 2019, 04:45:45 pm
Yes it is a perfect Archimate 2 flow. All other relationships in the same diagram are exported correctly.
It is a strange problem because I just created a new Archimate2 diagram and then it worked. Doing the same in another model, also with an Archimate 2 diagram, does not work. This erratic behaviour only occurs with Flow relations, not with other.
Post by: Glassboy on August 12, 2019, 07:41:05 am
I've seen some relationships end up with stereotypes from multiple ArchiMate versions.
Post by: michielper on August 14, 2019, 10:44:28 pm
Indeed, multiple boxes in multiple pulldowns may be checked. I find the assignment of stereotypes to elements a messy business.
