Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: JamesM on July 29, 2020, 11:18:13 pm
Title: Automatically Change the setting of ShowForeign in Diagram Properties via VBA
Post by: JamesM on July 29, 2020, 11:18:13 pm
I'm creating a VBA script to automatically establish a standard set of diagram properties.  I am unable to find how I can set the value for ShowForeign, as it is known in t_diagram, or Show Namespace as it is displayed within the tool.  Can anyone assist with the syntax necessary to achieve this.
Title: Re: Automatically Change the setting of ShowForeign in Diagram Properties via VBA
Post by: qwerty on July 30, 2020, 01:13:15 am
t_diagram.showForeign
(from p. 13 of my Inside book)
repository.execute("UPDATE t_diagram SET showForeign = 1 WHERE diagram_id = <theId>")
Not sure about the VBA syntax. Maybe you need to omit the parentheses.
Post by: Geert Bellekens on August 05, 2020, 04:00:21 am
In theory yes. You are only supposed to use parentheses when you are doing something with the return value.
So
a = function("parameter")is OK
is not supposed to be OK, but in this case you don't get an error. It's only if you have more than one parameter the you get a syntax error.
function("parameter1", "parameter2")
This should be written as
function "parameter1", "parameter2"
(Yes I agree, that is a weird ass syntax :-X)
Post by: Eve on August 05, 2020, 08:00:16 am
Presumably because it ends up being a parenthesized expression instead of parenthesis around the arguments.
