Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Pino on September 12, 2020, 02:01:25 am
Title: What about Visual Studio 2019?
Post by: Pino on September 12, 2020, 02:01:25 am
I got the Unified version without noticing that Visual Studio support goes up to VS2013... who uses that any longer? What's the point?  :-X
Is there any plan to support the current version of Visual Studio?
~Pino
Title: Re: What about Visual Studio 2019?
Post by: Aaron B on September 14, 2020, 12:56:05 pm
Hello Pino,
Importing Visual Studio projects is now built-in feature with Enterprise Architect and supports the current versions of Visual Studio. The MDG Integration for Visual Studio add-in (which is what I assume you were looking at) is no longer required. As you observed, the MDG Integration add-in only supported up to VS 2013.
See:
https://www.sparxsystems.com/enterprise_architect_user_guide/15.2/model_domains/code_import_projects.html
Post by: MichaelJ on September 14, 2020, 06:05:11 pm
... Importing Visual Studio projects is now built-in feature with Enterprise Architect and supports the current versions of Visual Studio. The MDG Integration for Visual Studio add-in (which is what I assume you were looking at) is no longer required...
Hi @Aaron,
On the "Compare Editions" page for Sparx EA, "Visual Studio Integration" is listed as a supported feature only for Unified and Ultimate editions. For these editions, does "integration" imply additional functionality? If Visual Studio integration is a part of all editions of EA, the product comparison page will need to be updated to reflect that ;-)
Post by: Pino on September 15, 2020, 05:35:15 am
Hi @Aaron,
As Michael pointed out, in the Compare Edition clearly states that VS Integration is not available below Unified. BTW, I can confirm that it doesn't work: it only retrieves the solution's tree but no .cs files at all. I end up with this tree in EA:
(https://i.gyazo.com/06948582d0d197dfdcd3af0b5909d9f0.png)
What am I missing here?
~Pino
Post by: Aaron B on September 15, 2020, 01:29:36 pm
@MichaelJ It's possible that our Compare Editions page needs to be updated in this regard - I'll ask about this.
@Pino In regards to the issues you're having, can you please either send an email to support@sparxsystems.com, or better yet submit a support request / bug report via the forms on our website? Provide as much detail as you can and any sample files where possible and we'll investigate it further.
Post by: Uffe on September 15, 2020, 02:32:53 pm
I can confirm that the solution import absolutely Does Not Work as advertised on Studio 2019, using Ultimate 15.1.1528 (there's no mention of this functionality in the 15.2 history).
I've tested with two different solutions.
One doesn't work at all:
The other solution has one C# project, for which a class model is generated.
It also has a WiX project, for which a package is generated but whose contents are completely ignored.
So no. It definitely doesn't work.
/Uffe
Post by: Pino on September 15, 2020, 11:24:54 pm
I just submitted a bug report. The webform tells me that a copy of my support request has also been sent to my email address but I've received nothing, same as per a previous bug I submitted last week. And no, nothing in spam either :D
Post by: Geert Bellekens on September 15, 2020, 11:32:49 pm
You might want to let support@sparxsystems.com know that.
A while ago I had the same issue, and there had been on a problem on their side, which they promptly fixed.
Post by: Pino on September 15, 2020, 11:37:00 pm
Hi Geert,
I just did that, thanks :)
~Pino
