Enterprise Architect => Uml Process => Topic started by: Ashar on September 24, 2003, 02:35:29 pm
Title: Shallow vs deep copying of sequence diagrams
Post by: Ashar on September 24, 2003, 02:35:29 pm
Hi: Been using EA for a week now... looks like a great product.
I am having trouble reusing elements of one sequence diagram in another. Reuse works if done manually with CTRL-Drag action, however, when I use shallow copying option, the only element that does not get duplicated is the actor.
I could use the manual way but the idea of not having to create all the messages repeatedly in similar diagrams is tempting...
Any ideas?
Ashar
Title: Re: Shallow vs deep copying of sequence diagrams
Post by: jvogt on September 25, 2003, 10:35:48 am
Noticed this in the other section:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=general;action=display;num=1064446290
Is this what you are looking for?
Regards,
Jesse
Post by: Ashar on September 25, 2003, 11:44:31 am
Thanks, the topic is same but the problem is different, actually it is the opposite. In the link you found, the problem seemed to be that messages were not being copied.
I not having any problems copying everything from one Seq to another. Problem is that I want to reference existing objects from a previous diagram without making a new copies of the objects.
Thanks for the help tough,
Ashar
Post by: funkiwan on October 19, 2003, 02:35:16 pm
I think I can answer part of your question.  To reuse objects between sequence diagrams:
1. Go to the Project View and create a new packaged called "shared"
2.  Still in the Project View, drag the objects you've created in your diagram that you want to include in other diagrams to your new "shared" folder.
3. To create a new diagram using the shared objects, just drag them to the new diagram.  This will create links back to the original object.  Changes made will be global to that object and will appear in all diagrams using it.  Objects specific to that diagram alone should be created in that diagram's package.
I would be interested to hear if anyone knows how to actually reuse sequences of messages between objects.  Recreating the same message sequences every time becomes tedious.
Jonathan.
