Author Topic: Problems moving requirements from DOORS to EA  (Read 1148 times)
sd
« on: March 18, 2003, 10:04:42 pm »
Hi!
DOORS can make almost any kind of file. Including .cvs.  In order to test this, I made an .cvs export, but there is no data ?? I selected a package where I saw a requirement, then I selected <edit/new> from Specification from .cvs, then selected fields : Requirement Difficulty, Requirement Priority, Name, GUID, Type. Then I pressed Save and then Run and View File, but it contained only headers. Similar problem with XML export XML export process stays blank and the file is not created. Id rather not to try import before I have made an export Id like to find out first the required syntax.
SD
PhilR
Re: Problems moving requirements from DOORS to EA
« Reply #1 on: March 19, 2003, 06:32:22 pm »
Make sure you have the "Export" option checked.  The default is "Import".
Works OK for me.
PhilR
