Author Topic: Errors after migrating to EA11  (Read 3121 times)
Guillaume
    • www.umlchannel.com
« on: May 13, 2014, 10:32:06 pm »
I have a number of shared projects in SQL Server + SVN where BPMN diagrams + linked documents have been defined.
I just upgraded to EA11 which lead to major issues on the existing project:
- I have a BPMN diagram which is located in a controlled package that's different from the package where nodes like activities are stored. If I select with a simple click an activity from the diagram, I get about 10 popup error messages "Cannot perform nesting operation. The parent item "" is locked" --> this makes the model unusable.
- We've documented many activities using EA Linked Documents; where existing linked documents can be accessed, it is no longer possible to create new ones on other activities. Have linked docs been replaced with something else in EA? How can we migrate? Why has it been disabled?
As it currently stands, I have to go back to EA10 as EA11 isn't compatible with the projects. This is the first time I'm getting major issues in migrating versions.
Guillaume
Jacob Vos
Re: Errors after migrating to EA11
« Reply #1 on: May 14, 2014, 02:59:19 pm »
I think that for such issues you better log a support request with Sparx. Last days I logged two issues with them that maybe are related. One had to do with the impossibility to draw BPMN message flows between pools that are placed wihtin a certain node in the Project Browser. The other was about the impossibility to add documents to the model. (I use an eap file.)
Guillaume
« Reply #2 on: May 22, 2014, 04:31:10 pm »
The issue has been confirmed as a bug by Sparx. Hopefully it will be fixed in  a future build.
Guillaume
tjs
« Reply #3 on: June 26, 2014, 11:38:06 pm »
Thanks for your research!
Is there a bug #, or link that shows EA has recognized this as a bug?  We want to track it to see which release its fixed in. z
It looks like this issue might be addressed in v11 r 1107:
http://www.sparxsystems.com/products/ea/history.html#1107
Can anyone confirm?
« Last Edit: June 26, 2014, 11:46:15 pm by tjs »
Guillaume
« Reply #4 on: June 27, 2014, 06:36:29 am »
I tested it again with the latest build 1007 ; this issue has been resolved  :)
Guillaume
Guillaume
« Reply #5 on: July 01, 2014, 10:05:28 am »
Is there a bug #
yes
can't, release notes do not include reference numbers
« Last Edit: July 01, 2014, 10:05:45 am by skiwi »
Using EA15.1 (1526) on Windows 10 Enterprise/64 bit. Repositories in SQLServer2014 R2 & Access2003/JET4.0
Jacob Vos
« Reply #6 on: July 01, 2014, 03:46:39 pm »
On May 14th I wrote: "The other [support issue] was about the impossibility to add documents to the model. (I use an eap file.) "
I now got feedback from Sparx on this issue. It turned out that adding documents inside your model is NOT meant to be in the Desktop nor in the Professional edition. The functionality that looks like you can do this in those versions, will be removed from those versions.
So for having documents inside your model you need version Corporate or higher.
- Jacob
« Reply #7 on: July 01, 2014, 08:07:20 pm »
- Jacob
You're kidding right?
Graham_Moir
« Reply #8 on: July 01, 2014, 09:08:11 pm »
I don't think he is.
I can see an argument for not supporting it in the Desktop version,  but doesn't make sense to me for the Professional version.
« Reply #9 on: July 02, 2014, 10:57:02 am »
The primary distinguishing feature between professional and corporate editions is a shared model for a team. If you don't have a shared model then there's not much point including documents directly within your model.
support@sparxsystems.com
Graham_Moir
« Reply #10 on: July 03, 2014, 02:43:21 am »
Hhhmm.  Well it would be good to be able to store all related information in one place whether it's a shared model or not.
« Reply #11 on: July 03, 2014, 03:45:28 am »
Another (plausible and legal) way to make more money  ;)
« Reply #12 on: July 03, 2014, 05:50:52 am »
I disagree, the benefit of storing documents in the model are, if anything, more valuable for a sole practitioner.
