Author Topic: Merge components  (Read 8718 times)
Sunshine
  • Its the results that count
Merge components
« on: October 31, 2014, 01:34:01 pm »
One of the common problem when modelling with a team of many people is that two people sometimes create the same object. It would be a really great feature to be able to merge objects. Something like dragging an object with the ctrl or shft key pressed in the project browser and dropping it onto the another of the same type. A dialog would pop up saying do you want to merge with options of overwrite target or source (for properties and tag values). Sparx EA would then merge the two objects into one, replacing the instances in diagrams and combining relationships with other objects.
This would facilitate rationalisation of objects when working large teams.
« Last Edit: October 31, 2014, 01:34:31 pm by phenzell »
Happy to help
Re: Merge components
« Reply #1 on: November 06, 2014, 12:37:37 pm »
yus, gets my vote
Using EA14.0 (1422) on Windows 10 Enterprise/64 bit. Repositories in SQLServer2014 R2 & Access2003/JET4.0
« Reply #2 on: November 06, 2014, 10:59:29 pm »
Yes. Though I think it's quite tricky to make it user friendly. Especially replacing occurrences of the replaced element (be it in diagrams or as classifier) is challenging.
Sunshine
« Reply #3 on: November 07, 2014, 07:34:25 am »
Tricky maybe but not impossible. I've seen it implemented on another tool  ;)
Happy to help
« Reply #4 on: November 07, 2014, 07:52:00 am »
I just wanted to point Sparx' nose in the right direction. They should make a requirements analysis followed by an use case synthesis, shouldn't they? Looking at most of the recent "improvements" I get the feeling that these were done directly from the programmers :P
François C
« Reply #5 on: December 12, 2019, 10:52:33 am »
That would really solve a lot of my problems. Do you know if it's been implemented finally?
« Reply #6 on: December 13, 2019, 12:12:26 pm »
lol
While it may have some challenges some basic ideas might be for an entity, or for a relationship (but not a package):
* aggregate notes, files, and similar
* aggregate tags (if different)
* move relationships from the object selected be replaced to the master object
* merge any relationships that are the same (sameness to be defined)
* update diagrams
might be trickier for classifiers and lot of other things
« Reply #7 on: December 13, 2019, 04:50:43 pm »
lol
* update diagrams
might be trickier for classifiers and lots of other things
We've done some work on defining (and processing) Semantic Equivalence of Arcs
« Reply #8 on: December 16, 2019, 08:32:45 am »
Please tell me more
« Reply #9 on: December 16, 2019, 09:38:59 am »
Please tell me more
It's not quite "rocket science", but as we discovered not trivial.  If you're really interested, we could start a new discussion specifically on this topic.  It may also help us to improve our mechanism.
Ours is written in VBA because it's handled by an EXCEL side-in, but the business rules would be generally applicable.
Glassboy
« Reply #10 on: December 16, 2019, 10:47:34 am »
I don't need a merge so much as a move relationships function.
« Reply #11 on: December 16, 2019, 07:03:40 pm »
Don't try and use the API.  It doesn't behave in any sane way.  Use SQL directly to remap the object_IDs.  However, once you've moved the relationships, you still have a potential consolidation problem (as we discovered).  So the question of Semantic Equivalence still applies.
« Reply #12 on: December 16, 2019, 09:38:59 pm »
I'm not sure why you say that Paolo.
I've written a bunch of scripts manipulating connectors, some even for the exact purpose of merging elements together.
In none of these I had any kind of trouble like you indicate.
« Reply #13 on: December 16, 2019, 09:41:43 pm »
You're all talking on a zombie thread. You won't see any of that coming from Sparx. Write your own merge (like Geert did).
« Reply #14 on: December 17, 2019, 09:21:55 am »
In none of these, I had any kind of trouble like you indicate.
The problem had to do with diagram links - not the connectors themselves.  Once you've got the connectors sorted, you need to sort out the diagrams they appear on - that's when you come across the problems.
