Author Topic: Add menu to execute script  (Read 2301 times)
Steve Wartik
  • Why aren't I outside?
« on: February 28, 2012, 08:47:23 am »
I've written some JScript code. I'd like the user to be able execute it through a menu. Specifically, I'd like to add a menu hierarchy to Extensions. Just like the ODM-related menu items, a script would be executed each time the user selects an item. Can someone tell me how to do this? Thanks.
Re: Add menu to execute script
« Reply #1 on: February 28, 2012, 05:27:59 pm »
Steve Wartik
« Reply #2 on: February 29, 2012, 12:28:23 am »
Geert,
An add-in is certainly a possibility, but I was hoping to package and distribute the capability I've developed using MDG. In other words, I'd like a user to select the Tools>MDG Technology Import item, load the file I'm distributing, then see my menus. I would prefer that the user not have to install an add-in too. Is that feasible?
Steve
« Reply #3 on: February 29, 2012, 12:32:08 am »
I don't know.
I've never used MDG before.
« Reply #4 on: February 29, 2012, 08:49:33 am »
Unfortunately, you can't add scripts from your technology into that menu. ODM has been explicitly added by Sparx.
support@sparxsystems.com
Steve Wartik
« Reply #5 on: February 29, 2012, 09:29:53 am »
Simon,
Thanks for the definitive response. Obviously not what I wanted to hear. Can I write an add-in that invokes JScript?
Steve
stao
« Reply #6 on: February 29, 2012, 11:01:15 am »
for which reason?
you can create an addin which does exactly the stuff you need.
no need for jscript.
Steve Wartik
« Reply #7 on: March 01, 2012, 12:30:10 am »
Well, the immediate reasons are: 1) I already have the JScript working; 2) I've never programmed in C#, I dislike Visual Basic, etc. In other words, I'm guessing that making use of my existing scripts would be quickest.
stao
« Reply #8 on: March 01, 2012, 02:03:06 am »
If you programmed in java you wont have any problems using C#
(i for myself started to develop an EA Addin withouth any C# experiences and it never was a problem)
If the jscripts dont do what they should i dont see any other possibilities than start a C# addin.
Its worth a try.
Steve Wartik
« Reply #9 on: March 03, 2012, 01:33:06 am »
Stao,
Okay, I'll give it a try. I hope you're right about Jave -> C#. Wish me luck!
