Author Topic: Using Quick Link to connect to distant objects in the same diagram  (Read 934 times)
SJ
How can I use quick link (or any other method) to connect 2 objects if these are not on the same screen ?
Thx
SJ
Re: Using Quick Link to connect to distant objects in the same diagram
« Reply #1 on: May 25, 2019, 02:46:44 pm »
Either put them closer together or use the relationship matrix.
« Reply #2 on: May 26, 2019, 08:28:34 am »
Another way is to zoom temporarily with pan&zoom.
KP
« Reply #3 on: May 27, 2019, 09:35:52 am »
Thx
SJ
And another way... if you drag a quicklink to the edge of the view, the diagram should start to scroll. You just need to know whereabouts the off-screen object is.
The Sparx Team
support@sparxsystems.com
« Reply #4 on: May 27, 2019, 05:59:07 pm »
Where again the pan&zoom window is helpful.
SJ
« Reply #5 on: May 28, 2019, 03:50:31 am »
Thanks!
Arquesoft (Mauricio Moya)
  • EA Consulting and development in Spanish
    • Arquesoft website
« Reply #6 on: May 28, 2019, 09:27:44 am »
Also consider important to use a physical mouse. EA is difficult to use with the embedded mouse of laptops
Need email notifications in EA? fully-automated baselines? a simple way to share your models via web? A copy of all your model diagrams in a folder? visit https://latam.arquesoft.com/en
natvig
  • I love YaBB 1G - SP1!
« Reply #7 on: May 28, 2019, 02:18:52 pm »
There is yet another method. You can drag the quick linker to an empty area of your diagram and press the Shift-key before choosing the target element type. You will then be prompted with the search dialog which allows you to search for any element in the whole model. The target element does not need to be present in any diagram.
