Author Topic: How to use the Subtype Property?  (Read 4922 times)
Modesto Vega
« on: May 04, 2021, 08:11:57 pm »
I cannot find any documentation on how to use the Subtype property, perhaps I have not looked hard enough.
The caption reads
"Name of an enumeration tagged value, in the form of "Profile::Stereotype::Tag". When the element is created, a sub-menu will list all the enumeration literals."
I understand this as meaning that I can create an enumeration with the subtype values and link it to the Subtype Property. However, since there is no way to select an existing enumeration, I am not sure how to link them.
Re: How to use the Subtype Property?
« Reply #1 on: May 05, 2021, 08:17:49 am »
Fill in the names of your profile, the stereotype defining the tag and the tag itself.
support@sparxsystems.com
Modesto Vega
« Reply #2 on: May 06, 2021, 12:56:29 am »
Thanks for the telegraphic answer.
Just for the record, this is what I had to do to get this working:
  • Create an enumeration with the desired subtype values
  • In Stereotype Properties/Tagged Values, add to the stereotype an enumeration specialised tagged value and point it to the enumeration created in the previous step
  • In Stereotype Properties/General, select metaclass being extended and in the subtype property enter the fully qualified name of the tag holding the subtype - e.g., MyProfile::Class:Type[/i]
    This should do the trick. Unfortunately, I cannot find anywhere in the documentation but perhaps I was too inpatient and did not look hard enough.
Re: How to use the _subtypeProperty?
« Reply #3 on: May 06, 2021, 09:48:13 am »
Hi Modesto,
A quick question.  You are trying to use this (_subtypeProperty) for elements other than Activity?  The implication of the Help is that it is for Activity only - since that is the only Element Type listed in the See also.  From your post, it seems to work for Class, yes?  Did you try anything else?
TIA,
« Last Edit: May 06, 2021, 09:50:14 am by Paolo F Cantoni »
KP
« Reply #4 on: May 06, 2021, 10:00:32 am »
Hi Modesto,
TIA,
I think you're reading too much into that 'See Also'. _subtypeProperty can be used with any metaclass, even connector metaclasses. All it does is set a tagged value on creation.
The Sparx Team
« Reply #5 on: May 06, 2021, 10:53:47 am »
Make sure the _subtypeProperty is specified on the metaclass.
Other than that, here's a working example.
<?xml version="1.0" encoding="windows-1252"?>
<UMLProfile profiletype="uml2">
<Documentation id="2D919350-9" name="Subtype" version="1.0" notes="Subtype"/>
<Content>
<Stereotypes>
<Stereotype name="Toast" notes="">
<AppliesTo>
<Apply type="Class">
<Property name="_subtypeProperty" value="Subtype::Toast::spread"/>
<Property name="isActive" value=""/>
</Apply>
</AppliesTo>
<TaggedValues>
<Tag name="spread" type="enumeration" description="" unit="" values="peanutButter,jam,vegemite,honey" default=""/>
</TaggedValues>
</Stereotype>
</Stereotypes>
<TaggedValueTypes/>
<ViewDefinitions/>
<Metamodel/>
</Content>
</UMLProfile>
« Reply #6 on: May 06, 2021, 05:31:36 pm »
Interesting! I right away tried that and, whoa!, there popped up a menu with the spread. Great! But wait, this is EA. Despite selecting one of the entries the property was empty then. I had to manually re-select it. This is a feature, I guess?
Let's see. Ah well, it's EAUI. You have to deselect the element and select it again. Then you see the property.
Wouldn't it be nice to have something developed that a customer could not start mocking about immediately?
« Reply #7 on: May 06, 2021, 06:11:22 pm »
[SNIP]
(my emphasis)
Maybe their testing mocks aren't "up to scratch"?  (couldn't resist)
« Reply #8 on: May 06, 2021, 07:32:38 pm »
Didn't we alread agree that Sparx' QA are their users?
Modesto Vega
« Reply #9 on: May 06, 2021, 08:01:47 pm »
Hi Modesto,
TIA,
Hi Paolo,
I am currently using it for classes and will soon used it for components. It works fine for classes and I expect the same for components. This allows me to flatten the meta-model.
The XML generated is a per Eve's last reply.
« Reply #10 on: August 02, 2021, 01:05:48 pm »
  • In Stereotype Properties/General, select metaclass being extended and in the subtype, property enter the fully qualified name of the tag holding the subtype - e.g., MyProfile::Class:Type[/i]
    This should do the trick. Unfortunately, I cannot find it anywhere in the documentation but perhaps I was too inpatient and did not look hard enough.
(my emphasis)
Hi Modesto,  finally getting around to having a look at this...
Firstly, I think the word you were after was impatient.  An in-patient is in a hospital (so maybe you were being accurate!)  ;)
I just want to clarify that the _subtypeProperty has to be in the (in our view incorrectly) Metaclass.  This, surely, is a property of the stereotype?
« Reply #11 on: August 02, 2021, 08:13:08 pm »
m an n are quite next to each other on the keyboard. Might simply be a typo. Comes ages, comes typo - my fingers do not seem to obey my brain they used to do.
« Reply #12 on: August 02, 2021, 10:14:00 pm »
m an n are quite next to each other on the keyboard. Might simply be a typo. Comes ages comes typos - my fingers do not seem to obey my brain they used to do.
I use a grammar checker that automatically indicates errors.  (it fixed up some of your above... ;))
Anyway, it "tickled my fancy"...
« Reply #13 on: August 03, 2021, 12:01:27 am »
Well, I wrote truely. With quite some (unwanted) typos. I like that proverb: if you find any spelling errors you may keep them.
