Author Topic: #including dependencies  (Read 1098 times)
cem
« on: April 08, 2011, 06:37:25 pm »
Is it possible to have EA C++ code generator to create #include directive for classes having dependency connector. I mean, I have ClassA and ClassB. ClassB is dependent on ClassA, that is, a dependency connector exists from ClassB to ClassA. When I generate the code, ClassB file has no line #include "ClassA". Is it possible to have this line, for example by tweaking code generation template?
Thank you...
Re: #including dependencies
« Reply #1 on: April 11, 2011, 08:20:22 am »
You can tweak the code templates although the C++ templates currently don't use the tweakable method.
If you look at the PHP templates for Import Section and Import you'll see how it can be done.
support@sparxsystems.com
